My advice to anyone upgrading to the after market system, if you are going all out... ... take the extra time and install a larger suction line in the tank. I think 90% of the problems with the stock junk (lp's) is right in the sub par fuel modules. I installed a 1/2" pipe in my tank a few months ago..... you would not believe the difference in the sound of the fass. QUOTE]
GKinney,
I'm certain that your Fass is quieter with the 1/2" pipe (I've tested it too) but the AirDog does NOT need the tank modification. The AirDog is engineered to work with the stock fuel tank/module. I've done quite a bit of research and a stand pipe/tank mod without a properly working air separation system will do more harm then good to your injection pump. Again, the AirDog is designed to work with the stock fuel tank and will flow properly and quietly stock or even with the "baddest" hotrod VP-44 out there.
Sorry RonA, there has never been a blue AirDog, you maybe confused with a larger unit not built for pickups. I'm amazed at the knowledge folks here on TDR possess when it comes to tires, clutches, torque convertors, injectors and electronic fueling enhancements. Tires are tires, black or black with white, who cares if they are 38" or 33" Michelin or Brandsmart? A orange Centerforce clutch should be the same as a nice red McCleod or Southbend but it costs less. Torque convertors? want purple, yellow, black or natural billet? I can get you a $300. 00 set of common rail injectors (exchange) but some guys on the left coast want $1200. 00! Even I know to flow more they just make the holes bigger, gee what can that cost? Banks, Edge, TST, Blue Chip all use circuit boards to enhance fueling so just pick the best color.
Whew, off my rant, but seriously, here a few differences. The AirDog is much more compact unit, different tire size so to speak. It flows different, it has a high pressure bypass (built in) to protect your fuel injection pump and it uses a diesel fuel filter. The Fass was copied from our design for Class 8 trucks, it's larger, flows different, has no internal bypass, uses a hydraulic filter for the fuel filter. The AirDog has primary and secondary air-separation, the Fass only secondary.
Anyone who has held an AirDog in one hand and the Fass in the other can see huge differences in construction. The Fass pump body is made in sections (slices) and uses gaskets to seal diesel fuel... ..... the AirDog has a one piece CNC machined body-no diesel gasket. The Fass has a band clamp (turbo clamp) and angle bracket to support (hold alignment) of the critical motor to pump alignment, the AirDog motor is machine bored into the pump body for proper alignment... . forever. This costs more... The Fass is red, the AirDog is black. When installed on your CTD you can see the Fass filters hanging below the bed or cab, not so with the AirDog. You must shutdown the engine of your Fass equipped truck to refuel, not so with the AirDog. The Fass furnishes a complete set of fittings and fuel lines, 3/8". The AirDog comes complete with 1/2" fuel lines/fittings.
It great that we as consumers have choices and I am very glad that the Fass has a great following, it was the first true diesel rated lift pump marketed to light trucks. I am also very concerned when I see misinformation about products... . saying they are the same, one just costs more. I owned and managed a repair shop and also sold hundreds of tires a year. I never told my customers that a $589. 00 set of Michelin built off branded tires were the same as a $679. 00 set of Michelin brand top of the line tire. They were not, two totally different tires with different rubber, tread pattern and strength. The warranty in no way showed the difference in performance or wear. Sorry for the long post. Larry
