Driving home last night my fuel pressure drops to zero and then goes negative. I have a new VP44HR on order so I don't sweat the VP damage and keep driving home.
I get home and whip out the multi meter - check the relay for operation and it's good, pull the relay and check the contacts are working ok, check that power is getting to the fuse and it is. Check the fuse and it's good too.
Hit the FASS pump with a hammer and it sprang to life, 17psi, and has been working fine since.
Sometimes the simple fix is the one that works. :-laf
