Engine/Transmission (1998.5 - 2002) Fass Rebuild Kit
2nd Gen Non-Engine/Transmission New Guy from Ohio
2nd Gen Non-Engine/Transmission HUB assembly removal
I have a FASS 150 with a serial number of 1197 which according to article below, that I found on the forum, is not covered by the warranty (only goes back to 5000). Does anyone know if the rebuild kit will work on my unit?
My FASS is very noisy, always has been. When I first bought it I tried to quiet it down, but could never figure it out.
When I saw the post below I thought O-Boy finally..... then my serial number is to low. Has anyone used the kit? How easy was it to install? Do you think it will work on mine?
Thanks for any help you can give me.
Paul Harlacher
770-463-8069
Well we have some very exciting news about what we have been working on the past few months. We have had a breakthrough with our R&D. We have found a way to lower pump noise up to 11 decibels from our testing. Our fuel pumps are consistently much quieter. For Example: Brads truck. He has a 2006 Dodge 3500. With the engine off and the windows down sitting in the cab, you can not hear the FASS running. So you can imagine with the engine running, the pump can’t be heard at all.
Granted, most of the pumps we released were quiet. We have seen some of you wish that your pumps were a bit quieter. We have listened and now have a program to reduce the noise. Here are the details:
For those with a seal on your pump (Lead seal and wire between the two horizontal motor bolts on the HPFP base or T-Block assembly of the FASS System. We have record of what pumps have seals and what pumps do not. ), you will need to send in your upper half of your pump for the update if it is a FASS. The unit does not need to be removed from the truck to remove the T-Block portion. HPFP's can be sent in as is. We do not want seals to be broken by anyone outside of our shop. If this happens, warranty will be void on that unit. We understand that this is an inconvenience (This is one of the reasons why we adjusted our warranty policy that is discussed later in this post) and this update will not cost anything but the initial shipping to send it to us. We will do what is necessary to make sure your pump is quieter when it is returned. We will run full tests to ensure a healthy pump. What we will need to accompany the pump is the following information:
-Serial Number of pump
-Name
-Correct Return Address (No P. O. Boxes)
-Put Number 2007-10,000 on outside of box
Please send in the full HPFP, with no fittings and mounting brackets installed.
We only need the upper half of the FASS system to be sent in.
This is the portion directly above the water separator that bolts to the filter base. It’s held on by 4 vertical (Up and Down) bolts, not the 4 horizontal (Left to Right) bolts with the seal! Removed this portion and send in to us for the update.
For those without the seals on the pump, we give you two options. You can send in your pump like above or purchase an update kit for $15. 00. This includes everything needed to update the pump in about 30-45 minutes. The order will be processed and an update kit will be drop shipped directly to you. Very simple. Instructions will have more details about tools needed and what’s involved. What you will need to do is send in a $15. 00 Check or money order to:
Diesel Performance Products
ATTN: Noise Update #2007-10,000
16240 Hwy O, Suite B
Marthasville, MO 63357
Include the following information:
-Name
Lastly, we are so confident in the changes we have made to improve the FASS/HPFP in the past year that we have decided to increase the warranty from 4 years to 6 years!! But this is not for just the new units being released or units being updated. This will be back dated to pump sold to July 2005. The serial number brakes are as follows:
95 Series FASS System: - ALL
150 Series FASS Systems: - Serial Numbers Back to 5,000
HPFP Models: - Serial Numbers Back to 1,000
We understand there are other options for fuel pumps on the market and appreciate your loyalty to our product. We are constantly improving and refining our pump to be the best on the market. This program and warranty upgrade is a way to say thanks for sticking with us. Here's to a New Year!
__________________
Diesel-Dan
Head of Wnty and Trouble Shooting
Currently running on B-100
2001 2500, TBK, FASS 150/150 #1603, Mach 2, Amsoil Dual Remote, Synergyn Synt. Oil
2002 VW Jetta TDI
Thanks, I PMed him. Would also like to know how hard it is to install the kit and if anyone else has ever done it? I wonder how much quititer it gets also.
Fass
Dan,
I am not sure about your answer. Is the noise level as different as night and day? If what "issue" is all that is the problem? Are you who I should be asking about the upgrade Kit? My FASS has a serial number of 1197 which does not look like it is covered by your post that I copied and pasted in my post.
Can you tell me how I can get the rebuild kit? Will it work on my FASS. I have had it on my truck for over five years, no problems other than noise. After I first purchased it I did all the test that were recommended, still noisy. I have lived with it and will continue to do so if I must. However, it would be nice if I could quiet it down. I tried to go to your vendor page but can't seem to link to it.
Paul Harlacher
770-463-8069
Dan,
I would like to get the updated motor and T-Block. Jannety Racing does not sell FASS anymore. Geno's Garage could not help me with the update. Can you adivse who I can go through to get this done? Thanks for the gret offer and the help.
Paul Harlacher.
Thanks Again Dan. I will call Genos. Like I said I did not talk to Kris or anyone else. Nothing came up on their web-site from a search for FASS. Just assumed that they no longer carried it. Sorry if I have caused you any problems with Jannetys. I guess I should have called first.
Paul
