Engine/Transmission (1998.5 - 2002) FASS with Mach 1.5's
Engine/Transmission (1998.5 - 2002) bigger fuel injector lines
Engine/Transmission (1998.5 - 2002) safe boost
Hello all,
I got my fass and injectors installed this weekend, and all I can say is wow what a difference. The only problem I have is the stock turbo is not enough with the comp on level 5, she gets warm in a hurry. I have not hand figured it yet, but the mileage looks better by the in cab readings. I would like to thank Matt Miller @ Trucks by Buck for the install. He is a great guy to work with.
Don't be too deceived by the overhead display, the more mods you make that change fuel flow the worse it will be as far as accuracy! Decide what avenue you want to take with the truck (daily driver empty, towing heavy, drags, pulling, etc) and then talk to the vendors about which turbo would best fit. Spool-up and EGT control will be major factors, and of course twins would be the ultimate!
