Michael,
Just checking to see how its going. I see you ordered a 25psi spring. I hope that aleviates your concerns. You could do the same by putting a washer in the return line fitting. If you remove the fitting marked "R" on the FASS, (3x4 inch wrench) carefull also this is a brass fitting in an aluminum housing, you will find a rubber o-ring on the fitting, (put some oil on it when you put it back together), also you will see the return valve spring and a composit ball the seats against a bevelled opening in the return line bore. Simply make sure the ball is in the hole, insert the new spring, the brass fitting and torque to 35 ft lbs using a 3/4" socket (no more, remember: Brass and Aluminum)...
You can just b put a brass or stainless steel washer between the spring and the brass fitting. You would need a metric washer with a 10mm center hole and an outside diameter of 17mm. Home Depot and Lowes have them in thier speciality hardware sections ($1. 06 for a pack of 6). I needed only one stainless steel washer to raise the pressure from 15psi to 23psi. Its not an exact science and you may have to play with it. But since you ordered a new spring use it instead.
Most people don't use the FASS on a 12valve because of the mechanical pumps reliability so the FASS usually comes set up for the VP-44 pump. 15psi for the VP-44 is way more than adequate on even a race engine. However, I've been running FASS units on 12 valves for a good while, all set at 15psi. Some for fun some under extreme work loads with never a problem and no mechanical pump. Its been an ongoing experiment shall we say into technology. But as EBottema pointed out a FASS on a 12 valve is like putting perfume on a hog :-laf . Its pretty cool, really makes the P7100 happy, can increase your fuel mileage and peformance a little, but isn't really necessary.
I hope your nerves are calmed a bit. Have fun, drive fast... . My fish are bitting and the boats leaving. See ya later.....
