I put two of them on my 01. No problem and I am over 204,000 miles now on my 6 speed. I think they are worth the effort as they add about 2 1/2 quarts of fluid along with that extra cooling.
I did notice that he offers a $20 adapter kit for the G56 and Getrags, hadn't seen that before.
Sam
OK, the extra fluid I can see, but you're telling me that two little pieces of aluminum are going to make any difference in temps of a aluminum cased trans?
Case in point: my trans (NV5600) will run 150*F, however the transfercase won't even be warm to the touch.
steved
Steve are you still running redline? Or did you change to something else.
Kind of like running extra fuel filtration and still having injectors fail ???
sorry I just had to say that
Bob
The transfer case is not changing the output shaft speed, it is one for one during normal operation. So the losses should be real low, therefore low heat gain. The nv5600 in 5th gear will operate with lower temperature then in 6th gear. The fast coolers are great, however on the right side the exhaust pipe is in the way to install. The next fluid change, I will need to mill an inch off and get shorter bolts. Steve are you still running redline? Or did you change to something else.
