Fat wheels and tires for up front ?
Dodge Must REALLY be Hurtin' to move the Leftover 2001's
Another lift pump going south
I remember ads in motorhome magazines advertising fat tires and wheels to replace the front wheels and tires on motorhomes. I would like to have such on my dually so the front wheels would be less likely to dig into the sand. Anybody tried that?
They are a bit on the narrow side, but its fairly common. However, the 255s and 285s are probably a bit tall for a 2wd (I think that is what you have?).
Pere
You should be able to get a 245-75 on the rim no trouble. My Mule(4x4) came with 245-75/16 tire with 16 x 6. 5 rims.
If you plan on replacing all the tires a 265-75/16 front and 265-85/16 back should give you enough clearance.
I know a guy with 4x4 dually put 265or 285 -75/16 all the way around. He put a spacer in between the wheels but his back tires are still close. If he puts a heavy load on his back tires are going to be rubbing. Should of had 85's on the back.
