Filter minder & K&N
money well spent
Font brake rotor paint peeling off - normal?
I am about to replace the stock filter with a K&N in the stock airbox. Will the filter minder still work/do it's job, or will it be worthless?
'97 Jeep TJ - Tons of stuff.
2001. 5 BR3500 Chassis Cab 4x4 163"wb - ETH/DEE, SLT, K&N in stock airbox, autometer boost/pyro, GTS clear headlight covers, no bed (yet). .
I have seen a truck with the 275's and a boost module pull down the filterminder with a clean K&N in the airbox. We removed the snorkel that goes from the airbox to the fender and then couldn't move the filterminder. We then replaced the paper filter and the filterminder didn't move. It appears that the snorkel is a bigger restriction than the filter, at least once you start even minor BOMBS. I wouldn't expect much from the filterminder with a K&N, especially if you take out that snorkel.
Hope that helps,
Mike
'99 QC 2500 SLT Driftwood 2wd SB 24v Auto 3. 55 LSD
ISSPRO pyrometer, Walker 21468, 20,000 miles 12-19-00
-- email address removed --
Howdy Agg's!
David:
I had the exact same thing happen on
my truck as what Mike described. The
"filter minder" never did work after
I put the K&N in. I now have a
"Psychotty Air Filter" which works
much better and my EGTS are at least
150 degrees lower!
John_P
Red '96 4x4 2500 Auto 3. 54, TST #5, Major Pump Mods(By "Scheid Diesel") 370 Diamond B Injectors, Gov. Spring kit, AFC Spring kit, Banks Exhaust, Prime Loc, Cummins Chrome Kit,Psychotty Air Filter, Pro-Torque Converter, BD Valve Body, BD Pressure Loc, Isspro Gauges, Sendel 16" Alum Wheels w/ 33" BFGs
Sounds good. I'll ignore it.
