Rob,
Check your Map sensor connections.
--Justin
--Justin
Originally posted by Rob Thomas
#@$%! #@$%! Let's hope not.
Ok, no go on the valve adjustment.
I got the codes today. .
P0121
Accelerator Pedal Position Sensor Signal Volts Do Not Agree w/Idle Validation Signal
P0216
Fuel Injection Pump Timing Failure
P1689
No Communication Between ECM & Injection Pump Module
Now at least I have a direction to go.
Later, Rob
Originally posted by RGilbert
P0216
This is usually related to having the wrong pump key when installing a new pump. Since you have not installed a new pump, your timing controler is probably going nuts on the injector pump. Check that your Crank and Cam positioning sensor are functioning. The pump gets its inital time from the crank, but it also uses the cam along with a handful of items for timing. This could also be comming from a faulty APPS sensor.
Originally posted by Evan A. Beck
If you get GAS, YOU will be the one needing a new VP, Mr. Merrick... *LOL*![]()
Originally posted by DEZLPWR
Hey Evan,
Are NEW VP's still available for purchase, or are we are left with is remans?:{ :{
I have heard a ton of differing answers to this simple question!![]()
Originally posted by KatDiesel
Yes there are new ones. They will cost more and are harder to find tho.
Originally posted by DarrellB
If you guys would quit trashing them there would be more available.![]()
Just a thought.![]()
DB
