First gen springs for 10100gvw?
Turning electric trailer brake drums
Manual Trannies
I have a first gen and I tow with it. It looks like somebody removed the stock overload springs and snubs. Does anyone know if a w-350 1992 dually should have overloads at this rating? And where can I buy some to replace the old ones? Thanks
1992 W-350 Club Cab Dually 3. 5" straight pipe(thanks jardine!)
W-350 8' contractors dump with 3. 5"BD exhaust, 16cm^2 housing, DI pyro&boost
Russell
My dad has an 80 model One ton Crew Cab dually that does not have overloads. It does have one hell of a spring pack though. A few years ago i hauled 3500lbs of scrap metal in it and it set level still!
Clark
1999 2500 QC SB 5spd Flowmaster 3 chamber, K&N Re-0880
1968 Barracuda Formula S Viper Blue 11. 98@112
NHRA member for life
Thanks Bad340fish, I'm going to buy a 20' enclosed Pace I'll see how it sits with that on it. One of my good buddys around here does restoration work on cars and boats, his 440 car has a tag CUDAMAN, I love dodge sounds like you have a nice pair #ad
My previous truck was a D350 chassis cab dually with the 10,100lb GVWR. It had huge leafs and overloads in the back, stock.
'97 Jeep TJ - Tons of stuff.
2001. 5 BR3500 Chassis Cab 4x4 163"wb - ETH/DEE, SLT, K&N in stock airbox, autometer boost/pyro, GTS clear headlight covers, no bed (yet). .
I had a '92 D350 Club Cab with 10,100 GVWR and no overload springs either. The truck was built in March 92 in Mexico.
I towed a smaller 5th wheel than I now have with a hitch weight of 1700 lbs and it lowered the rear bumper about 4 inches.
Bill
Y2K 3500QC, 6 Speed, 4. 10, SLT+, Camper & Tow Pkg. , Westin Chrome Nerf Bars, Mopar Flaps, Reese 20K Hitch, EGT & Boost Gauges, RPM 45 Gallon Aux. Fuel Tank, Highway Products 5th Wheel Toolbox, ECM Controlled PacBrake, Painless Wiring Kit, Mag-Hytec Diff. Cover, Rancho 9000, Air Lift 5000 Air Bags, TOYS: '97 Hitchhiker II 31' 5th Wheel, 2 slideouts, 19,750 GCW, '94 Lance 990 11' 3" Slide-In Camper, Torque-Lift Camper Tiedowns
i have a 93 4x4 duelly w/ factory
overload springs not many have it.
look under hood for option list
its on bottom side of hood.
mine says optional hd rear axle springs
lists weight # ,( did not go look at now)
i put a 4000lb lance on it and still higher
in back then front sits,
if you want them , i bet dealer sells
spring perch mounts (factory) new
spacers( not sure if needed)
springs try good spring shop.
problem w/ just adding more springs is all
weight is one one set of perchases
while a gd overload set has new seperate
spring perch's ( spelling)
good luck ps if you need i can look up
weight # and code on option list
1993 w350 ex cab, banks,nv 4500 in
open exaust, pw Injectors are in. Big rig flaps,tach in,. Its loud and goes ok, for a 93,Ham radio Call KK6dm
has ability to communicate any where in the world. Headliner shelf
5 antenna's
I pulled a 24' Vintage trailer loaded with a mustang with my dads 80 model, about 7K total behind the truck. Had the car pulled up so far the front wheels were in the middle of the side door. Truck set level still. With my 99 we can only put the nose of the car up to the door until the truck sags and sits on the overloads. You don't need a mouthpiece to ride in mine though lol #ad
Clark
Clark
