Got my first oil analysis back today from OAI. Oil is Amsoil 15W40HDD. Filters are Fleetgaurd Statapore full flow and Amsoil BE100 by pass. Oil had 4999K on it when the sample was taken and it was taken hot. Truck has 27 and change K on it and went to synthetics at 21K with 1k change at first to flush out the dino gunk. Got my numbers back and did a search on TDR to compare and still have questions.
Is there a place to find what the limits are for a given value? There is no comparison on the test report against what the oil should be. Here are my numbers:
iron-9
chromium-0
lead-1
copper-12
tin-0
aluminium-2
nickel-0
silver-0
silicon-5
boron-4
sodium-0
magnesium-21
calcium-3730
barium-0
phosphorus-1107
zinc-1322
molybedenum-0
titaium-0
potasium-0
fuel- less than 1%
Visc. @100C was 13. 42
water-0%
soot/solids-0. 1%
Glycol-negative
TBN-9. 91
oxidation-12. 0
f-soot (?)-. 01
No corrective action req. oil suitable for continued use.
So what do u think? Good/Bad/indifferent? Is there a source to compare against? I'm thinking about sampling again in another 5k or should I check sooner?
Only make up oil was for a full flow and by pass when I switched from the BMK15 to the BMK 11 single by pass. Maybe 3qts when that occured, but that was at 1k on the oil.
Thanks in advance.
J-
iron-9
chromium-0
lead-1
copper-12
tin-0
aluminium-2
nickel-0
silver-0
silicon-5
boron-4
sodium-0
magnesium-21
calcium-3730
barium-0
phosphorus-1107
zinc-1322
molybedenum-0
titaium-0
potasium-0
fuel- less than 1%
water-0%
soot/solids-0. 1%
Glycol-negative
TBN-9. 91
oxidation-12. 0
f-soot (?)-. 01
Thanks in advance.
J-
