Men, I have been lurking around this site for a couple of years, have just purchased my
subscription. A bit of info about me, I work for John Deere Farm equipment company, as
a service tech, and farm part time in NEMO. I have owned my 91. 5 250 4x4 for 3 years
and have over 292,500 miles on it.
My questions are:
What is normal stock boost pressure, I am running 5-10 psi under good load at wide open
throttle.
Every now and then my pickup does not want to shut off. I cycle the key switch a time or
two and it will dye. I have never had to use the fuel shut off lever on the pump yet.
How far can you screw down the aneroid? I have the screw just a little below flush with
the jam nut removed.
My front axle is starting to look like a ford with the 2 piece axle. the wheels are towing
out at the bottom bad. Everything feels tight while jacked up, or is it just an elusion with
the rounded shape of the body?
Sorry about the book. Jon
My questions are:
throttle.
