Gary - K7GLD said:
The only middle of the road solution I have seen is a T Rex, http://www.ihot.us/Motorcycle_Photos.cfm?PID=75
I drove one at a car show this past summer that was for sale.
That thing really looks neat - wonder what it's based on for running gear? A shaft driv water cooled one would be a real kick - like a Honda Goldwing...
What price class are they?
I've seen them in the mid $20,000. 00 range, but alot of dealers are listing them for nearly twice that. At $20,000. 00 I was still interested, but only because I knew I could not build the thing for that. The engine is a 1200 CC race bike engine. The construction is all custom and very well designed, everything on this trike is brand new. (engine included), that's hard to find without buying a production bike and stripping it for parts yourself.
It doesn't care which gear you start out in, it just goes.
A goldwing would not be a good candidate for this trike. It is a full on race car on three wheels, which a goldwing could not satisfy the power and speed requirements this thing is capable of. I had the one I drove up over 130 mph in the distance of around a 1/4 mile, it was just as stable at that speed as 55. There was PLENTY left to go when I backed out of it. Mortality is a funny thing, I realize it more and more with each passing year after 30
This is the actual website for the manufacturer:
http://www.go-t-rex.com
If you're interested, here's the specs:
tubular steel chassis frame.
Engine: 1164cc Inline 4 cyl. , DOHC, with Ram-Air.
Transmission: Sequential 6-Speed close ratio gear box, purpose designed reverse gear, rear wheel torque damper.
Front suspension: Unequal opposed triangular arms, adjustable dampers with coil overs, sway bar.
Rear suspension: Swinging arm, dual adjustable dampers with coil overs.
Steering: Rack and pinion (2. 25 turns lock-to-lock), leather steering wheel.
Brakes: Front discs: Cross-drilled discs, 11in. (280mm) diameter, 4-piston aluminum calipers.
Rear discs: Cross-drilled disc, 10in. (254mm) diameter, 2-piston aluminum caliper.
Wheels and Tires : Aluminum 7"x16" front, 11"x17" rear, 195/50/ZR16 front tires, 315/35/ZR17 rear tire.
Body: Reinforced fiberglass plastic-sandwich construction, carbon fiber windscreens and headrests.
Cockpit: Side-by-side 2-person seating, adjustable backs, adjustable foot-pedal box, 3-point retractable safety belts.
Dimensions: Wheelbase: 90in(2286mm);
Width: 78in. (1981mm);
Length: 138in. (3500mm);
Height: 42in. (1067mm);
Dry Weight: 900lbs (410kg).
Fuel Capacity: 7. 5 US gal. (28L).
Performance: 0-60 mph: 4. 1 sec.
Top speed: 140 mph.
Lateral acceleration:1. 9g.
(the listed top speed is very very modest to say the least, I was keeping up with several 750 and 900 cc sport bikes with no problem).
