I have read the other post in this forum about how easy it is to change the fuel filter but I have some more questions that were not asked.
1. When you remove the threaded cover will fuel leak out?
2. Is it necessary to drain the canister and if so is the drain the black lift handle located at the bottom?
3. Will I be better off refilling the canister before priming with the lift pump?
If anyone can answer these questions I would sure appreciate it.
Thanks in advance... ..... Steve.
