Well had my first pull of the new truck (SO, 47re) to say the least the truck pull great down the freeway.
I do not like the shift points of the transmission at 45 mph the trans locks into OD no matter the throttle position, I will select the O/D to off until I reach 55 mph, then shift to O/D. I might do the disconnect the battery thing then reconnect turn key to ON then depress the go pedal slowly down and back to see if I might be able to change the shift points.
Back to the pull, I pulled east on I- 95 to PA up and down hills in O/D and out, In O/D I would loose about 6-10 mph (starting from about 68-65), RPMs would drop down to 1400-1500. A couple of times I almost shifted out of O/D.
So far so good!!
So far so good!!
