I got my new CIPA mirrors from Genos A little over a week ago 95% pleased with them. Only thing that bothered me was that the drivers side mirror's natural position was swung so far out that even with the power mirror adjusted all the way in I could not get a good view behind me. I have heard several people on here complaining about the same thing so I know this is not a fluke on just mine. So me being the curious person I am I pulled them apart to see just how this was all set up. By the way these things are built very solid, nicely put together as well. Seems odd to me they can design the rest so well and miss this important part. Anyway, here's the deal. It will take about an hour or so if you have all the right tools. It will take me a few posts to get all the graphics up with the right descriptions but I will do my best to make sure I detail it all for anyone wanting to do this.
First of all I am going to describe the mechanism they use and the principles I followed in making my decision to adjust it the way I did. Their is of course other ways to achive the same basic results and if you have time and a good ability with a welder there is an ever better option than mine. I just went the fast and efficient route that still gives me solid results.
Basically there is a u- shaped main bracket. The two arms that extend out to the mirror and a center post that is your min pivot point. on that point there are two small pieces welded on(shown below).
They work like this when in the base bracket.
I had at first been trying to figure out how to either cut the center rod out and reweld it with those two pieces rotated to the needed position or cut or grind of the two small pieces and weld a new one on in the correct position. then I had another idea. thinking about using a grinder why not just grind down the one to reduce the angle. See below... ...
After I had done this I started to worry I may have reduced the amount of distance the spring is compressed and therefore reduced the amount of tension holding the mirror from swinging in or out. Since I had already ground it down though I figured I might as well throw it together and see how it did. It works fine, plenty of tension to hold the mirror in place. No increased vibration driving down the gravel roads to the farm place. so i feel good about it. Easy enough to grind off and put on a new one if I needed to so I am not worried about future wear either.
