Finally had a couple of nice cool days this past week and fixed the mega cab. I actually have some nice cool air and it blows VERY well now.
A HUGE thanks goes out to Scbroder & to Kry226 for their posts concerning the HVAC system. I printed out both step by step processes & was able to complete the job with little difficulty.
Scbroder's post is here:
https://www.turbodieselregister.com...ussions-faq/176307-hvac-removal-pictures.html
Kry226's post is here:
https://www.turbodieselregister.com...93-hvac-heater-treater-doors-replacement.html
Had three of my doors broken. The recirc door was broken at both ends of the axle shaft and was laying on top of the fan, so there wasn't much air being flowed. The blend door was broken at the shaft as was mode 1 door. I bought the mode 2 door as well but ended up not using it since heater treater doesnt take into account the mega cab on those trucks. The mega actually has another set of "doors" that are couple via rod/cam setup to the mode 2 door. The second set of doors is probably 3"x3" each (two of them) and open/close at the same time as the mode two door and controls the air flow to the REAR vents. The motor that opens/closes mode 2 door is set on a set of "towers" that holds the motor away from the box to allow the cam & rod to travel underneath it to open/close the doors. Neither the mode 2 or the doors to the rear air appeared to have any wear to them either. I wasn't completely satisfied with Heater Treater either. I emailed them and asked them to contact me asap so I could figure out what needed to be done. Two days after I emailed them (and decided to just put it all back together without their mode 2 door) they replied and said they didnt have enough of a market for the one like I have (the mega cabs) and that I should just wedge the doors to the rear vents open and cut the "towers" down so that the motor will engage with the end of the mode 2 door. SO... Heater Treater Doors: AWESOME... Heater Treater Customer Service: SUCKS.
I also cut the screen out of the top that everone reccommends. That worked well too.
I also added a couple of 3/4" ball valves to the heater core lines.
Dont forget to have a set of the a/c line disconnect tools handy when you start too.
Be VERY careful when you're taking the bolts out of the top of the dash (specifically the two 10mm bolts) and DONT crack the windshield... Like I did. Lucky for me I have comprehensive on my insurance!
If anyone has any questions feel free to email me at firefighter_2000 AT hotmail DOT com, or just reply here. Will do my best.
Craig
Craig
