Flaming Banks
Horton fan install - feedback
New company vehicle
I need to say a bit more here. After realizing that the title of this thread is “Flaming Banks”, I find myself becoming agitated at the fact that we get flamed based on misinformation and improper testing. I want to address Ramboy’s post in greater detail.
First, let me describe a typical test sequence that we use. As I mentioned before, we have a fully computerized chassis dyno which is capable of sustained loads of 1500 HP and 3200 lb/ft of torque. In addition, we have an engine dyno capable of 2500 HP and 2500 lb/ft sustained, also fully electronic, but is a water brake style rather electric brake. Our first step is to put massive amounts of data acquisition equipment on the vehicle, allowing us to monitor everything from vacuum in the air filter housing to boost pressures, from ambient air temperature to turbine inlet temperature, and everything in between. Our dataloggers are capable of sample rates of over 100 samples per second, but for a typical test we sample at a rate of about 20 samples per second per channel (usually in excess of 20 channels).
Then we run a baseline test on the vehicle. This is done to establish the stock characteristics of the vehicle and is used as the basis for all comparisons to follow. I am compelled to point out that a baseline was not established on Phil Gorham’s truck (Ramboy). We begin by running full power and torque curves on the dyno, selecting an RPM range that extends above the horsepower peak and the upshift point, and extends below the torque peak and the backshift point. Conditions are as controlled as can be; cooling air is delivered to the tires of the vehicle, 60 MPH of wind is directed through the grill, the engine is brought up to a sustained operating temperature (known as heat-soak), the transmission is held in direct drive and the torque converter is locked, effectively giving a direct drive (1:1 input to output ratio) through the transmission. Once the dyno testing is completed, the vehicle is taken on the road for acceleration testing, both in solo form, and with a weight trailer, bringing the combined vehicle weight up to the Gross Combined Weight Rating of the vehicle. Road testing includes 0-60 MPH and 40-60 MPH accelerations, a fuel economy loop, and hill climb testing. Without a specified set of test conditions in a stock configuration, it is not possible to properly evaluate the gains.
All of these test criteria are then repeated with whatever equipment is being tested. It should be noted that in development we typically make only one change at a time, and then test to evaluate it’s benefit. When multiple changes are made, you may not be able to determine what change was responsible for a given result.
One other side note about out test methods; in order for testing to be comparative, it is necessary to eliminate as many variables as possible. Some are eliminated within the format mentioned above, but some simply cannot be controlled, such as weather conditions. When these conditions vary, we use SAE standardized correction factors, which allow us to make comparisons even when weather conditions change from test to test.
Now let me comment on the problems that I see with the problems that I see in Ramboy’s tests. First, there is no baseline test. That means that you really have nothing to compare your “after” numbers to. How can we know for certain that the calibration on the dyno that you are using is not off by 50 HP? Having a baseline eliminates those types of questions.
Your test is not a test of a Banks PowerPack. You have multiple products on the vehicle, all of which will affect the performance in some way. And I disagree with your opinion that the TLC temperature limiting function was not a factor. The TLC function is designed to protect your engine by reducing fueling when the temperature reaches a certain point. But it can only reduce fueling that is delivered via the OttoMind. With the injectors that you had installed, it is possible that the fuel delivery of the OttoMind was quite diminished, perhaps even completely removed. You suggested that the next time you test, you intend to do so with this feature disabled, but I can tell you now that will not be possible without special programming to the OttoMind. The OttoMind has a failsafe design, which does not allow it to deliver fuel if an EGT signal is not present.
You have made your assumptions based on the factory advertised flywheel numbers, minus a 15% drivetrain loss. Upon what do you base that assumption? Not only do we find that drivetrain losses will vary dramatically from vehicle to vehicle, but factory advertised numbers are not always what they seem to be. If you truly wanted to know the drivetrain loss, you would not only need to dyno the truck on a chassis dyno, you would need to remove the engine from the vehicle, along with all of its driven accessories, and run it on an engine dyno. But what really matters? Real world numbers are rear wheel numbers, again showing the importance of baseline testing. You need something to compare to. For the record, the 1999 automatic truck (rated at 215 HP) that is used in our printed literature had a stock rear-wheel horsepower peak of 179. 3 HP at 2700 RPM, and a rear-wheel torque peak of 372. 9 lb/ft at 1800 RPM.
In our advertising we typically use the words “up to” because those ads represent multiple levels of systems that are available for a given application. If you are at all familiar with our product line, you will know that we offer 4 levels for your 99 Dodge Cummins; Git-Kit, Stinger, Stinger-Plus and PowerPack. Only the PowerPack delivers the highest gains. I went back and looked at past ads in TDR and those that use the numbers 127 HP and 311 lb/ft of torque make it very clear that those numbers relate to the PowerPack for a 12-valve. Those ads are also very clear that for specific information for your vehicle, you should call our toll free number a request a Test Report. This is not a “misrepresentation” at all, much less a “serious” one as you have stated.
It should also be pointed out that we typically print conservative numbers. It is not uncommon for us to receive reports back from customers that are attaining better than advertised results from their vehicles.
Mr. Gorham, please refrain from “flaming” us when your information is incomplete and your testing is inaccurate. If you have a complaint, you are more than welcome to call us and we can discuss the details, but it is highly unfair of you to flame us without the facts being clear. If you would like to talk to me directly about this, e-mail me your phone number and I will be happy to call you to discuss your test methods, or you can contact our Technical Service Department toll-free at (888) 839-2700.
Bravo PeterT. It's nice to see Banks stickinig up for itself. I for one am sick and tired of these posts that "Banks doesn't live up to claims or Banks Customer service sucks". It appears to me that the TDR has a large population of members that do not understand product development and testing and shoot their mouths off before all the data has been collected & digested.
PeterT - may I suggest that Banks submit an article to the TDR on how your products are developed. Maybe a facility tour during DieselFest @ GET Dodge?
As a side note - the Banks air filter is essentially a K&N, correct? In a recent issue of TDR there was a statement that the K&N filter does not meet Cummins filter test (I don't recall the test standard). Has Banks (or K&N) tested their filters to the Cummins spec?
Brian
Peter, this was an excellent response and should shed a lot of light on the expected gains of any modification.
To all on the TDR,
I have a Power Pack on my truck (after removing a PE box). I visited the Banks shop in Azusa, and, whereas several members have noted deficiencies in Banks' customer service and sales departments, their R&D facilities, manufacturing facilities and engineering seem to be top notch.
I would certainly say that Banks' R&D and engineering facilities are of greater caliber than our own backyards and garages!!
I bought a Banks Powerpack because it was designed as a system : with a computer, boost modification, exhaust, air filter, Ram air, etc... . : the stuff was all designed to work together . Yes, there are less expensive ways to get power, but they may often be detrimental to the life of the engine. Why would we (most of whom are probably not mechanical/electrical engineers) expect to be able to hodge-podge a working system together by buying various parts from different manufacturers that have never been tested together - and get great results?!? :confused:
I would say its analagous to playing pharmacist... . we are mixing these great drugs together, but don't stop to check if the drugs interact! The results could be deadly!:eek:
Just my two cents
Peter,
Are you telling me that there were no claims for h. p. or torque gains for my truck when I purchased my system? Then I stand by my original claim of misrepresentation because your salesman did, in fact, tell me I would receive those gains. I suppose it was naive on my part to not realize that those gains were achieved under ideal laboratory conditions. But then your ads do not say this, do they? Maybe I was wrong to make such a knee-jerk reaction to the dyno results. But I will have it dyno'd again on a different model and, rest assured, good or bad you will hear about it.
NVR FNSH
Where is your signature? I would like to see how much Banks equipment you have on your truck. There have been unfavorable posts on this forum about Psycotty and not once did I see "Tell them, not us". There have been unfavorable posts about BD and not once did I see "Tell them, not us". The list could go on and on and NOT ONCE did I see, "Tell them, not us". And now, I have been asked to tell them, not you. It sounds as if a few of you are encouraging a form of censorship. If there is something bad mentioned about a product you have, you don't want to hear it. I was under the impression that these forums were for members to post their suspicions, beliefs and experiences. Never have I seen anything stating that results leading to these suspicions or beliefs had to be obtained under ideal lab conditions. There has been serious bad-mouthing of Banks in the past by many of you. I supported them and not once did I say "Tell them, not us".
Ramboy,
I don't post a signature because I don't feel the need to waste the bandwidth. That said, I do not have any Banks equipment on my truck. As a matter of fact all I have is a VA CPC that I bought used when everybody on this site had to buy a Edge PE because it was the latest greatest thing since sliced bread & Jim Bob has one so I better get one too. My father recently had the Banks set up installed on his '96 by the Power Shop and he has nothing but good things to say about it. I have not driven it with their 13K 5th wheel in tow so I don't feel that I can offer a legitimate opinion.
I'm not trying to censor anybody - period. I would like to see a more responsible, professional approach to the way people are posting about their testing & results. TXRam's post on the Psychotty was a decent thread IMO. If your post had been bashing DD I'd still feel the same way. Just seems like everybody has to jump on the Banks bandwagon.
Brian
Originally posted by Ramboy
NVR FNSH
Suspicions are just that - suspicions. With out facts to back up your suspicions your statements don't mean anything. Had you run a baseline and posted your info we wouldn't be having this discussion.
Brian
. Now I am convinced the injectors delivered as promised.
Exactly, how were you convinced that the injectors delivered as promised? Did you do a baseline dyno run? How 'bout a baseline dragstrip run?
Brian
Baseline
Phil, lets get back to your baseline. I still have your stock injectors sitting in my garage (John is gonna kill me) and disconnect the Banks system, its only the electronics that has to be removed. I doubt that leaving on the high ram intake and exhaust will make much if any difference, will It PeterT? As for the injectors, they cannot deliver as promised if you are cutting back on fuel. PeterT I've seen Ramboys truck and your statement of the Ottomind automatically reducing addtional fuel delivery is not totally correct. If that was the case, there would be know reason for the Ottomind to be connected is series to the APPS/TPS output signal. The Ottomind cuts back on total fuel delivery, as in electronically backing off the throttle. I'm not bashing the Banks system, it is very well thought out and the only true way to control EGTs.
Steve St. Laurent and Ramafid
The drapstrip is going to be no help to Phil with the TLC of the Ottomind hooked up. It would be like taking off from the lights at full throttle and then backing out of it about half track.
Just a few facts ...
Dean, I think you and a few others that were present can attest to this too.
While dyno'ing trucks in Houston several months ago, we dyno'ed one 24V 5-speed with the Banks set-up and one 24V 5-speed with a PowerEdge (no hot setting). The dyno was a dynojet.
The Banks equipped truck dyno'ed about 250HP, while the PowerEdge equipped truck dyno'ed between 280 & 290HP. With an EZ Edge on the latter truck (with the PE off), the dyno was almost the same as the Banks equipped truck (about 245HP).
Just a fact I wanted to present, because, no - dyno's are not the best or most consistent way of measuring HP, but this was a side-by-side comparison of very similar trucks with different power enhancements on the same dyno within an hour of each other.
Clint, yes I was there when those trucks dyno'ed and remember how poorly the Banks equiped truck did and the look on the owners face after a Edge'd truck turned the rollers.
I agree the dyno may not be the best place to look at horsepower. I'll bet Phil's truck would give me a run for my money due to the auto vs stick until top end, but how many of us are driving around at 100mph all the time.
I'm not pro or con Banks or any other manufactures products. To eaach his own, heck I drive a plain jane ST and for the life of me cant fiqure out why anyone would need a leather wrapped lazyboy on wheels. Let the flaming begin.
I would have to say that without actual testing of the truck on the same Dyno when it was stock, there would be no real starting point for you to determine "Gained" HP. The Banks kits are designed (one of the reasons I chose them) to work together when installed on (assuming) a stock engine. While it will obviously work fine with additional mods, those mods might effect your final outcome. Just my 02 worth.
Kev
Brian,
I like the idea of providing more information about how we test. I am currently working on a post to give more detail. As far as tours go, we offer them anytime someone requests one. If anyone is interested, just call ahead about a day in advance so that we can be sure to have someone available. You can ask for me specifically, or talk to Rich in the Marketing department. Between the two of us, we will make sure that you get a complete tour of the facility.
Banks uses multiple suppliers for air filters, but they are all a cotton gauze style construction. We have also followed the threads, comments and suggestions about filters here, and after doing our own testing and evaluation, we have determined that the filter design is a good one and provides good filtration as well as being non-restrictive. The main thing that I would recommend is that if you do operate your vehicle in heavily dusty conditions, that you clean the filter more often than the normally recommend interval.
Phil,
I did not say that we did not have data to offer you when you purchased your system. The numbers that you referred to in your post related to a 12-valve application and were never represented as anything else. All you need to do to receive information about your application is request it. Our records indicate that literature was mailed to you on two separate occasions, so there should be no need for you to rely on the numbers that you saw in an ad that relate to the 12-valve engine. If you would like another copy sent to you, just let me know and I will make sure that it gets sent.
As far as your comment about “ideal laboratory conditions” is concerned, I thought I made it clear in my previous post why we take the testing approach that we do, but I will go into greater detail in another post about this subject. Perhaps that will help clear the air on the issue.
WeirCummin,
As far as getting back to the factory settings for a baseline reading, if this is a complete PowerPack installation, then the components involved are an air filter, High-Ram casting, turbine housing, complete 4” exhaust, and OttoMind. The air filter and OttoMind should be easy to deal with, the rest of the stuff would be a bit more of a pain to swap out. If you were to leave those components in place, just realize that you will have less inlet restriction (and improved flow), less exhaust restriction, and higher boost. All of this contributes to improved engine efficiency, and although this does not account for the full horsepower gain of a PowerPack, there will be some improvement with just those components. Just keep that in mind as you test. If you would like to discuss some good test methods before you proceed, just e-mail me your phone number and I will give you a call to discuss.
The OttoMind does not make any changes to the function of factory fuel delivery or have any impact on the flow of the injectors. It can only remove fuel that it has added over and above the rest of the vehicles fueling system. The interface with the TPS only serves to evaluate rate of throttle change, it is not used to reduce a throttle signal. The throttle signal going to the Cummins ECU will always be equivalent to the actual position of the throttle, it is not modified by the OttoMind.
