Fleetguard Addtive for DPF Equipped Vehicles
Optima Yellow Tops/Power Inverter
Heavy load downshift from 6th to 5th question
Cummins Filtration shows some fuel additives on their site, one in particular seems to be intended for engines with DPFs called Platinum Plus® DFX-DPF Catalyst.
They indicate it is designed for use with vehicles having Diesel Particulate Filters (DPFs) and is formulated with cerium and higher levels of platinum catalyst to provide more complete combustion, reduce particulate matter emissions, and reduce trap regeneration temperatures.
Not sure if this would be considered an “approved” additive over others, but found it interesting to see something targeted for DPF equipped vehicles.
Go to Cummins Filtration and search for section 8 of document LT32599 (Fuel & Emissions Additives)
They mention that it is good with #2 diesel, low sulfur diesel fuel, kerosene, and biodiesel blends. Did they just miss ULSD or is it not compatible I wonder.
I checked the site, read the doc. I would like to try this additive to see how it works. Does it help fuel mileage, and help reduce EGR soot loading in the oil?
I checked Geno's - not shown as available, so I sent an email inquiring same.
Thanks, Luke
