A couple years ago, I went to a training seminar for oil and oil filtering. Here are some data that was given out at that time.
"Micron Ratings are arbitrary values assigned to filters or media. Although a "micron" is a length (1 millionth of a meter), a "micron rating" is not actually a measured value. "
The micron rating for a filter quotes a particle size without establishing the filter's efficiency at removing that size of particles. A window screen will remove some 1 micron particles, but it will not be very efficient. Since a micron rating cannot be verified, filter manufacturers are safe in assigning any number that they want.
To compare filters, the filter industry has established standardized tests for measuring performance. These tests include Life and Efficiency Tests (SAE J726, J806, and J905) and Beta Ratio Tests (SAE J1858). These SAE standardized test methods, along with the meticulous recording of test conditions, ensure that filter comparisons are "apples to apples. "
Life and Efficiency Tests measure the filter's ability to remove a standardized contaminant from a standardized fluid that is flowing at a constant rate and a constant temperature. The test continues until the contamination trapped in the media raises the differential pressure drop across the filter to a specific, predetermined level. Life and Efficiency Test results will include a Time Weighted Efficiency (%) and a Capacity (grams).
Beta Ratio Tests are by far the most accurate and objective way to compare the performance of filters. A Beta Ratio Test measures a filter's ability to remove particles of given sizes. In other words, the test measures the filter's efficiencies at specific particle sizes. The beta ratio test equipment actually counts the particles in the fluid before the filter and after the filter.
Now the Amsoil BE-90 (By-Pass element) has a "Beta Ratio" of 85. 63 and is 98. 6 % efficient @ 3 Micron. The BE-90 element is identical to the larger BE-100 element except the BE100 element is designed for a larger capacity oil sump. Looking at the chart that was given out at that seminar, the BE-90 was 99. 8 % efficient and had a "Beta ratio" greater than 100 @ 5 Micron.
The "other" benefits listed was the ability to remove water (up to a pint, BE-90) Non-Channeling design, and increased filtration capacity. These filters are of the "stacked disc" design, and are only for By-Pass installations. In other words, they are too restrictive to be used as "full-flow" elements.
Wayne
amsoilman
