Got to put in my 2 cents.
First off $540 for 7hp is crazy. But then you have the added mpg.
How long would it take to make the investment gaining 3mpg ?
Spent $6000 on my diesel, got almost 200k on it, another 100k and I'll be saving on my fuel. breakeven is about 300k miles.
Sorry Reb, got to ask how reliable can a 1200hp truck be.
My tuppence:
If I install the 262, it won't be for added HP, nor for increased fuel economy. It will be to ensure that I have adequate air flow through the A/C condensor, trans cooler and radiator at low engine speeds. At highway speeds, there is usually enough air flowing through without the fan. I want the A/C to work at any and all speeds; it has almost never worked at low vehicle and engine speeds.
I didn't buy the diesel for fuel economy. I bought it for longevity. And it's still doing OK at 235K miles. Other than some front end, brake and suspension components and a couple other minor things, the truck has needed very little maintenance. In fact, the third oil pressure sensor, known for early failure, has now failed, but only after 6 years and 140K miles. The Optima red top batteries are now 5. 5 years old and going strong after 130K miles. The commercial intake heater relays I fabbed are still running great after 5. 5 years and 130K miles. I replaced the fan clutch the last time I replaced the oil pressure sensor; it works well enough, but is showing signs of age.
I certainly didn't buy the Dodge/Cummins for the fuel economy. Nor did I buy it as an investment - investments are supposed to appreciate in value, whilst nearly all automotive vehicles only depreciate in value. I bought it because I wanted reliable, long-lived transportation. The money-savings has come from not having major repairs to fix once or twice a year. I think the Flex-a-Lite 262 would be a fine addition to the few carefully-chosen BOMBs I've installed on my truck, because Flex-a-Lite's reputation is similar to that of Optima, Stancor and the few other manufacturers I've used: solid.
I haven't forgotten that our trucks are Better Off Modified, Baby!
N
