My head lights have been flickering for a while and was thinking that it might be the solenoids for the grid heater or a loose ground. But tonight the headlights went out entirely while driving down the road and didn't come back on until I wiggled the headlight switch. Did a search on the headlight switch and then went and checked the headlight connector. Just like a lot of others it was melted and on the way to catching fire. The green wire marked "H" had melted the entire little housing where the spade connector goes into. It had also been repaired once before. My question is what does the "H" connector go to? Is there a tab key so I can remove the spade connectors from the housing so I don't have to cut and splice the entire light harness?Any Ideas to improve the process?
WD
WD
