Flip up towing mirrors
Spray-in bed liners??
BLue Chip box good on smog
DieselB59
After a month's wait for another DC nationwide backorder, my towing mirrors arrived. I first saw them on Bigsaint's 3500 truck at the Ida's dyno day. I just had to get them for my 2500. When flipped in the up position they make the truck look like a little KW T2000! The blind spot mirrors integrated into them are really trick too. I had to sacrifice the power mirror option to do the install, but for the looks and operation of them, who cares? I'll be needing them for towing the racer out to Muncie in a week and a half. I wish the truck came with a set of mirrors like these, it's nice to see into those blind spots after four years of getting a stiff neck.
Chris Timochko
*Association of Diesel Specialists Certified*
AUTO WURKS DIESEL R&D TEAM
1997 5sp 4X4, Rhino Linings, Espar Heater, A. W. D. HX40 turbo, ATS 3pc Manifold, BD 4" Brake, Marine Compression, A. W. D. Custom Tuned Injection Pump, A. W. D. Intercooler, A. W. D. /Mallory Fuel System and Braided Stainless Lines, A. W. D. 370B Injection Nozzles, Delivery Valves, Governor & AFC Spring Kit, Psychotty Air, NOS Diesel Kit, A. W. D. 6" Chrome Exhaust System, BD No Smoke Valet Switch, McLeod Dual Disc Clutch, Mag-Hytec Rear Cover, Cummins Chrome Kit, Optima Red Tops, Hadley Bully Horns, Hurst Line Loc, Goodyear Wrangler AT/S 305/70/16s. 15. 50@97mph on Goodyear All-Terrain tires. Dynoed at Ida's: 435 hp at the rear wheels.
Project U96 - 1996 3500 2WD racer. A. W. D. Marine Ultra Low Compression, A. W. D. Teflon-coated Pistons, A. W. D. High Lift Camshaft, Ported and Honed Cylinder Head, Intake and Exhaust manifold; A. W. D. HX40 Turbocharger, ATS 3pc Exhaust Manifold, A. W. D. Water Mist Injection, A. W. D. Custom Fabricated Fuel System, Race Spec A. W. D. /BD P7100 Injection Pump, A. W. D. Custom High Flow Fuel Injection Nozzles, BD Auto transmission and Custom TC, Weld Draglites, Goodyear Eagle Drag Slicks, 5" Single Stack Through The Bed, Mag-Hytec on Rear and Transmission. 11. 54@115mph
Chris, my local Dodge dealer has been sitting on at least several sets of the new flip-up style tow mirror retro. kits. I didn't know they were on National backorder. Oh well, knowing my local dealer they'd want a premium for them anyway. #ad
As cool as those bad boys are, I decided to go a different route... I purchased a set of the new generation (i. e. , complete redesign + the heated feature) Power Vision mirrors for my Ram. I really didn't want to lose the electric adjustment or heated features of my OE mirrors. To that end, I waited almost three years to get these (I wanted a set since before my Ram arrived in June of '98 although, I didn't want to lose the heated feature... with all the rain we have here they would fog up all the time #ad
see, everybody's happy. #ad
John Treibel
'98. 5 2500 QC 4x4 Sport, Glasstite Vision II, 285 BFG A/Ts on M/T Challengers, Warn 4X Boards, Mopar fender flares & tow hooks, NW Custom s/s-rubber mud flaps and accs. , Mag-Hytec diff. cover & DD trans. pan, Edelbrock IAS shocks, Reese Titan V hitch, Jordan Research Ultima 2020 trailer brake controller, next gen. (heated) Power Vision mirrors, SPA gauges (3), Dynamat, '00 Sport grille and headlights/PIAA Super White bulbs, "special" Brite-Box, PIAA Dual Sport 900 aux. lights, BD exh. brake, Amsoil Dual Remote Bypass w. trick billet block adapter and Aeroquip Teflon-s/s hoses, Optima Yellow Tops, DD3s and DD TTPM, Aeroquip AQP s/s fuel hoses, tricked out Cummins valve cover, tricked out Banks High-Ram and 14 cm2 (wastegated) turbine housing, ATS 3-piece exh. man. , Banks 4" dia. s/s exh. sys. , DTT 93% TC, DTT custom tuned VB, BD modified trans. front pump (enhanced by DTT), Air Bulldog induction hood (with NACA ducts), plus MANY other trick modifications
COMING ATTRACTIONS: break out those sun glasses! Plus, BLACKOUT gets a "BIG GULP"
NRA Life (Patron) member
I have to agree with DieselB59, I put a set on my 97 while I was on vacation in Hot Springs Ark. I had to take a little road trip to a dealer in Little Rock, but they had them on the shelf. It took long to go and get them than it did to put them on. Total cost for the kit was $283!
It makes pulling a 5th wheel a lot easier, when you can see what it coming up behind you and also backing it. .
Rick
RICK
97 2500,CC,5 SPEED, 3. 54 Limited Slip,Psychotty System,K&N, Pre-Turbo ISSPRO 3" Pyrometer & Boost Guage,Silencer Ring Removed
15,000 RBW 5th Wheel Hitch,25' Excel 5th Wheel,Rancho RSX17000 Shocks,Amsoil Dealer,Straight Piped
I looked at the flip up mirrors but didn't want to give up the power and heat functions. For a little over $100 more I got the Lucerix X-Mounts. Easy to install and look great.
'98 2500 RC, 2WD, 12V, 5 sp. , 4. 10 LSD, TST #11 plate, K&N RE-0880 & 25-0880, Autometer boost & pyro, X-Mount pwr/htd mirrors
Guys - Were these flip-up style mirrors ever offered as a factory installed option?
when I ordered my truck in April 2000 I asked the dealer about these flip-up mirrors as an option and he didn't know what I was talking about. I had seen them on a 99 Ram and thought they were factory installed. The guy who owned the truck did not indicate otherwise. I assumed therefore that Dodge did not offer them as an option on the 2001 model. I now have on order a set of Lucerix (sp) that should be arriving soon.
Thanks,
Richard
Richard: The flip-up style mirrors were a factory option that became available with the "late" 2000 models. I tried to order them for my "early" 2000, but to no avail, and had to install them later when they became available.
2000 Qc LWB ETC 6Sp 3:54 LSD, + all the options except leather, BD Stage ll Injectors,Edge EZ, Psychotty& K&N,
BD E-Brake with Shifter Control, ISSPRO EGT and Boost Gauges, Transfer Flow 50 Gal. Alum. Fuel Tank, Line X
16K Hijacker Double Rocker, Pulling a 35Ft. triple slide Spinnaker 5vr.
1996 Viper GTS
Suzuki DRZ400
1100 Yamaha Cruiser
I'm wanting to update my '97 power mirrors with the 98+ style and heated & powered features.
Anyone want to sell their discarded 98+ units?
Cheers;
John
-- email address removed --
[This message has been edited by JohnE (edited 05-30-2001). ]
Thanks,
Richard
I didn't order my truck, it came off the dealer's lot. I bought it in Febuary of 2000 and it does have the flip up mirrors.
Michael
2000 QC 2500 5sp swb 2wd 4. 10
PGP key id:0x8BB389F7 Finger Print: BD0B 4CCE BB08 0BCB A8DD F4A3 9CBA B96B
Chris, glad to see you finally got them and they are installed, sorry to hear you had to do it in the rain (this past weekend ?), but if it makes you feel any better, you were not the only brave sole out their getting wet while working on his truck #ad
Scott W.
White 2001. 5 3500 ETH/DEE 4X4 Quad cab SLT,tow package and camper prep,Husky liners front and rear,DiPricol pyro,boost and oil temp gauges,SPA fuel pressure and temp. gauge,Edge EZ,Psychotty air,Bully Dog stage III injectors,ATS 3 piece manifold,HX40 turbo,4" BD exhaust,4" BD E-brake,McLeod clutch,Mallory 4150 lift pump,Mag-Hytec rear,Go-Rhino grill guard,Lund bug shield,PM tractor utility back up lights,Penda bed mat,365. 8 HP on the dyno and blow by bottle is bye bye !!! I love the smell of diesel in the morning, it reminds me of... . VICTORY !!!
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1231655&a=9089608" TARGET=_blank><font color=red>My Truck</font></A>
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1231655&a=9089604" TARGET=_blank><font color=red>THE SAINTS</font></A>
I heard that the flip up mirrors will have the heat? and power next year. I had the smaller mirrors on my Y2K, got the flip outs on my Y2K01, and miss th4e power and heat terribly. They are GREAT for towing, but look at the glass when adjusting. They are going to break sometime, as mine did at MM. After I dropped my 5er, I folded them back in, and pressing on the edge of the driver's side mirror, it broke on the end near the spot mirror. I wasn't too upset, as I knew it was only a matter of time.
So, it's either get the Lucerix, or wait and get the updated OEM. Decisions, decisions, decisions!!!!! #ad
Shane Oler
'01 2500 4X4 QC, ETH/DEE, Dark Garnet/Camel, Autometer (made for Diesel Dynamics) Pyro (pre-turbo)and Boost Pillar mount, PE EZ, Cobra CB w/ Dual 4' Firestik II's, 4" DD exhaust, K&N, BIG-O 255/85R16 AT's, Custom stereo (nothing stock), Genuine Steel* Grill gaurd and nerf bars, 20K Reese 5er hitch
Other: '70 Olds Vista Cruiser 455 (future resto project)
30' Sandpiper 5er Super Slide bunkhouse(about 10k lbs. )
Chris, Glad you like the mirrors. I put my set on a few weeks back before my trip out to Montana to pick up my new slide in camper. I ordered my set on a tuesday and had them by friday. Just my local friend at the parts counter. Anyway they are awesome. I would not be able to live without them after having them now. Kinda like the hp as well. No what I mean.
RED 98 3500 12v 4x4 Quad Cab SLT Larimie, 4"BD exhaust and brake, triple mount AutoMeter Ultra Lights on the pillar, governor spring kit, delivery valves, 370 B injectors, 332-700 camplate, 16 cm2, new carter lift pump,B&M Hammer Shifter, Catz Foglights,New Factory towing mirrors,Mag-Hytec diff,South Bend Clutch, Hellwig AirBags,Horton Fan Clutch, NorthWest "Fear This" mudflaps,custom dynamic timed pump by AWD,Linex,Cup Smoothie,Tonneau cover w/ bike rack over the bed,Billet grill and bumpers inserts, Eclipse w/center seat sub enclosure and remote alarm,Super hitch.
2001 S & S 11DB Slide In Camper
80 Porsche 911 SC Turbo Look Porsche Club Racing Trackcar, Totally Bombed
Cannondale Killer V 900 SL
