Floor Pan Replacement, W350
New Truck, Found a Rarity in Alaska
Hood Pads
Here goes...
Shortly after buying my '93 D350, I found the rust. Installing new starter contacts, I saw what appeared to be a minute bubble on the underside of the driver's floorpan.
I'd consider myself a decent welder, how hard could a simple floorpan be??
Shortly thereafter, removed the carpet - and found this:
Rest of the cab looked like this:
Ordered a replacement floor pan from Sherman, via Amazon... Pan was $56, shipping to Kodiak (a remote Alaskan island) was $75!
Began cutting... And cutting...
After degreasing, the cab mounts appeared to be in excellent condition. I'm fairly confident that the previous owner regularly oiled the underbody of this truck.
I was extremely lucky; as the rust was entirely isolated to the driver's floorpan. None of it whatsoever had made it's was to the cab mount or frame/rockers. Interesting really, I figure the combination of the stock water trap jute insulation / water intrusion is what accelerated rust on that side. The spot welds were where the worst rust damage seemed to be occurring.
I had to modify the floor pan quite a bit. The major flat areas of the panel fit well; where I had trouble was where the replacement pan met the transmission hump, and by the firewall. I had to fabricate/form a "scab" piece that entirely covered the area beneath the pedals, as rust had made it's mark there as well.
Primed with "Weld Thru-It" zinc rich weldable primer.
Cab mount / Frame Primed
Waiting for primer to dry, I focused on the seat. As the legs had developed some heavy scale where they mated with the saturated carpeting.
Needlegunned / Degreased
Primered:
I'll skip the boring and ugly welding pictures... (Butt welded fully)
Being the first floorpan repair I've ever attempted - there were a few rookie mistakes that I made, which added significant time and frustration to the fit up process. Namely, attempting to measure / cut the panel without having it in place in the truck. Also, ignoring nearly all of the advice that I'd come across - I was premature with a few cuts, that ended up leaving significant gaps around the replacement panel. I'd venture that these mistakes easily added a day to the project.
Here is is fitted up:
Also, the entire cab floor was sanded with 36 Grit on a random air orbital (for paint prep). All areas of slight rust were sanded, those that were heavier were coated with Ospho (converts rust to iron phosphate).
Decided to use a two part epoxy paint and primer system, as I'm intimately familiar with it after years of painting the commercial fishing vessel that I captain.
Holds up extremely well; and leaves a high gloss finish.
One coat of primer (impregnated with aluminum); 3M Urethane seam sealer on both cab and underside on all welds.
Two finish coats: (Bad lighting too!)
Hope that she'll be good to go for another few years at least!
Seat goes in tomorrow after the paint has had time to cure.
Contemplating a vinyl carpet and sound deadening material. I'm already diesel deaf from my time spent on the water...
Sure this was your first time?
Looks great, nice work. Impressed!
You’ve used some coatings and chemicals I’ve never heard of before, could you please repeat them in a list with detail?
Thanks!
Thanks!
Thanks Wayne. I tried to do it right the first time. Years of running a commercial fishing vessel in Kodiak has made me hate rust..
Here’s what I used in order:
Dev Prep (Surface degreaser / paint softener)
Ospho (similar to Corroseal) - converts rust into harmless iron phosphate
Intershield 300V (aluminum rich primer, 2 part epoxy)
Interthane 990V (high gloss epoxy topcoat)
