I have a question for you guys running a Fluid Damper. I just chucked a serpentine belt and in the process of changing it, I found out that the belt does not fit between the damper and the fan pulley. So I have to loosen the four bolts that hold the idler pulley and the fan pulley. Is this normal?
Thanks
Dustin
Thanks
Dustin
