I have to agree with Wayne about using any of the 5W-30 oils from Amsoil. I went to NV regarding the "after market" lubricant for this transmission. When I purchase my next truck it'll have the 5600. I wanted to confirm, when that time comes, I could keep using the Amsoil products. I asked "What could be used instead of the mopar fluid you'd get from the dealer?" The tech said that the 5600 uses a synthetic 30-weight oil. He also said I could use any high quality multi-grade 5W-30 SYNTHETIC OIL. The oil oil has to have an additive for the synchronized gears. This additive is found in the higher end Synthetic 5W-30 oils. This was later confirmed with a call to an Amsoil tech.
I've had to do some research regarding my next truck, and I've been reading the old issues of the TDR. I came across a section in "The Shade Tree" in Issue #37 page 105 talking about the NV5600.
"The New Venture 5600 gearbox uses a synthetic 30-weight oil. From New Venture literature we know to use the Mopar 4874464 part number. However, Pennzoil Synchromesh, 30-weight, synthetic fluid has been confirmed as an acceptable alternative. " This was from our own Robert Patton.
If you have questions regarding what can be used instead of OEM, call New Venture and ask.
Paul
Yes, I am an Amsoil Dealer
Paul
