Steve Graham said:Rob, There is a harmonic balancer off of a marine 4BTA that you could use. If your goal is to reduce the vibration at idle and throuth out the rpm range the harmonic balancer will be of little help. Best bet is some Fluidlastic mounts if you have room for them or you could do like I did and drill two 3/8's holes lenght wise through the 92 dodge 6BTA mounts. This works very well and reducing the felt vibration.
Steve
