Engine/Transmission (1994 - 1998) Fluidampnr drill pin kit
Engine/Transmission (1994 - 1998) P pump parts
Engine/Transmission (1994 - 1998) exhaust temperature
I see this kit is available for engines that are going to spin 3500 rpm and higher. I was wondering if this can be installed with engine in the truck or not. Thanks.
It can be done in the truck as already stated.
Here is the thread B Kirk did way back when about his Fluidampr install and how much of a PIA the pin kit was,LOL. IF your not planning on rpms over 4k then you probably do not need the pin kit,howevermif your planning on higher then you should add it. mine is pinned and I can remember how much brumbling was done by the guy who did the dampner install when he did the pin kit while the motor was in the truck... ... Andy
https://www.turbodieselregister.com...n/165173-12-valve-fluidampr-install-pics.html
