Or the bolts weren't properly torqued in the first place. Vibration/movement has enlarged the threaded holes on the crank causeing loose fitting bolts,that caused the bolts to loosen the 2nd time. Might have to tap the crank bolt holes to the next size up. Easy enough to check so that it doesn't happen again with the new flywheel.
