Fog lights inop
Exhaust housings
how long to leave original oil in new truck?
My fog lights went out the oyther Day I spent today checking all
the things that I thought could go wrong. Getting power where I checked fuses and things. can any one give Me another starting point. Thanks inadvance
wire loom/connector
If you haven't taken a look the wires loom passes thru 2 holes in the crossmember under the rad. There is a connector that you can unplug when the front bumper in taken off. :confused: A place to start. Good luck, hope you find the problem soon.
Jeff
checked power to fog lights
I am getting power to the plug that connects to the fog light. how in the world do You go about changing the bulbs. It seems strange
both would go they look good on what I can see. What next?
I don't know about yours, but on mine the bulbs come out with a 1/3rd turn in the socket.
While checking power to the connection, did you check continuity to ground?
Jay
Mine went out while running down the highway a few months back. It was a defective headlight/foglight switch.
