2nd Gen Non-Engine/Transmission Fog lights
Hello all, I bought driving / fog lights to go in the holes in the front bumper. I was under the truck today, and it looks as if I will have to remove the bumper to get them mounted. Is it hard to remover the bumper? Been driving truck for 2. 5 years and tired of looking at empty holes. Any advice appreciated.
bgroom
I added a pair of cyber white driving lights into the holes a couple of weeks ago. There was a bracket on each side of the holes that allowed me to mount the driving light bracket into. I had to buy some longer bolts to bolt into the brackets and do a little twisting of my hands here and there, but they look great. Hopefully you should have those as well, look up from underneath the truck to see.
Good Luck
Lights
If they are factory lights they mount to the back of the bumper and yes you will have to remove it or at least remove it enough to get access to the rear side. It is not hard to remove, I broke the snaps off on the plastic cover but they can be unsnapped from underneath. The bumper mounting bolts have 18MM heads if I remember right. You have to drill out a plastic rivet on each end of the bumper also. If you got the factory mounting kit, it comes with a new head light switch, a relay and some wiring, don't connect the red wire if you want the lights to operate with high beams on. bg
And, if they're Mopar foglamps, you'll need new sight shields:
55076786AB SHIELD, Bumper w/o Sports Package w/Fog Lamps, Right
55076787AB SHIELD, Bumper w/o Sports Package w/Fog Lamps, Left
Originally posted by Thomas
And, if they're Mopar foglamps, you'll need new sigh shields:
Yep, I forgot those, they came in the kit I bought. bg:eek:
