Engine/Transmission (1998.5 - 2002) Follow up to lift pump survey
Engine/Transmission (1998.5 - 2002) Dodge Lift Pump Cure ?
Lift pump survey
02/49900/QuadLong/stock/no failure/currently 12 idle, 8. 5 loaded, ? WOT.
Originally was about 14 idle, 10. 5 loaded, 9 WOT. I am trying to keep it at or above 8 psi when loaded to keep enough flow going to the injection pump. If it goes below 8, I am going to the dealer and request one under my extended warranty. If they won't help, then I am installing the STANADYNE Fuel Manager 33945 (10 psi regulated flow, up to 80gph, near the tank) and bypass the original equipment pump.
Downed Pump
99/2500 auto/4x4/VA box 53 cracked at 18,000 miles, lift pump failed at 18,001 Towed to dealer again. Current mileage: 46,000 :cool:
foxracer1 said:
99/3500/4x4/SLT QC/5spd (5th gear failed at 80,000)/86,000/van akien box, lager injectors, mangnaflow/ no lift pump failure :confused:
01/2500/4x4/SLT QC/AT/89,000/no mods other than transmission box for lock up/also no lift pump failure :confused:
99/3500/4x4/SLT QC/5spd/84,000/van akien box,straight pipe/ no lift pump failure :confused:
The above 01/2500/4x4/SLT QC/AT/ @ about 100,000 replaced injection pump/ super chips plug in tuner
other trucks okay
also new work truck 01 3500 100,000 no pump problems in the past 10,000
GIT-R-DONE said:
First lift pump went out at 29,000 , installed FASS. VP44 replaced under warranty after excessive 0216 code and dead pedal @ 47,000.
Would you recomend the FASS? also what does the 0216 code mean? dead pedal sounds like i need a lift pump replacement
