Bosch made a brass advance piston. I think they thought it would work better, NOPE. Then they went to a steel advance piston.
What the advance piston does is advance or retard the timing, ie critical to the operation of the VP pump. Does A LOT of moving back and forth and is a significant wear point. When the advance piston fails everything else in the VP44 quits. As the advance piston is failing (not maintaining position, missing the angle of advance requested, etc it throws the 0216 code)
The brass advance cylinder seems to have shown up in about 02 and hence there are a lot of 02 failures. Subsequent rebuilt pumps have steel advance pistons. There have been several "updates" to the rebuilding scheme. Therefore you want to make sure you are getting a completely up to date and current pump to get all the updates.
"I bet if you put some diesel in the spare vp and plug the holes it will last quite awhile as a spare... ... chris" might be "pickled" and hold for a long time, who knows.
Bob Weis
Bob Weis
