What do you like about it?
While I applaud the placement of the exhaust valves on the inboard side in order to reduce manifold bends, I just don't like it from a maintenance perspective.
Personally, I think the only "proper" turbo arrangement for a vee engine is with each turbo fed from one bank.
I hate to be a naysayer, but that thing looks like a nightmare.
Ryan
IMO, there are several advantages to this design. A couple that come to mind:
Exhaust heat rises for a very short, direct trip up to turbo/turbos. Quick spool, very little heat loss.
Compactness/versatility. W/O the exh. manifolds/pipes on each side of the engine, it allows for a much narrower engine pkge. Very important for use in smaller trucks or cars. Especially for V-8/V-6 front wheel drive applications.
As for maintenance regarding the new turbo location? I can't see any big disadvantages, but I'd just have to wait and see on that. As for all the engine clutter, pulleys, etc? I can see the cab lifted off the frame a lot!
As a side note. IMO, turbos on ea. side of a gasoline V-8 works great, but can be very cumbersome. My thinking is, as this new design evolves, I would not be surprised to see it also tried on gasoline fueled V-8/V6 platforms also.
For diesel engines, if I'm going to have two turbos, there will be one turbo blowing into the other. Thats the big advantage for our trucks, with the in line six.
I never liked the way they plumbed the exh. pipes to the turbo, on any of the V-8 diesels. The turbos are way too far away from the heat source.
Ray
