Cummins724
I lost 3rd gear 2 weeks ago in my nv4500 & had my trans rebuilt, but when I got it back from the mechanic who installed the trans..... it still shifted hard. I thought something else was wrong with it. I pulled the shifter to see if I could find the binding problem. When shifting into 3rd,5th & reverse... . It felt like the shifter was rubbing on something & binding up. I found that it was a easy fix... . the plate that is beneath the shifter [spacer] that has the 4 sleeves going through it needed adjustment. It was off center & only about 1/16" which made the shifts feel notchy. I adjusted it & tried it 3 times before finally getting it where it needed to be. I always thought that if it was installed... . it was good, but it is unbelievable how much difference it made. I have nice smooth shifts now & not even a little binding at all. Just thought I'd share my experience with you guys.
