Engine/Transmission (1998.5 - 2002) found the CHOKE in the system
Engine/Transmission (1998.5 - 2002) why more horsepower??
:D Today I installed a new line beteen the out port on the lift pump to the in port on the fuel filter. I used 3/8th`s 90*`s on both the points mentioned above and used push-lok hose to make the connection. NOW! the good part, Gained 1# of fuel pressure @ idle and was consistant across the board until I did a WOT with the TST PM 111 comp and gained 3# from previous readings , F/P used to fall to 2# now can not get it below 6#. I am so happy I could S#$%. Two more lines to replace and who knows what kind of gains will be made. BTW this is with a stock lift pump! Just had to share the good news
:D
Let us know what happens when you replace the other two lines. It looks like you are getting some good fuel pressure numbers.
Edward
