I'm working on a frame swap project. I'm pretty attached to MY truck but would really like the use of 4x4. Assuming I've got a 4x4 frame and front axle and suspension components, will everything else swap right over?
rear axle:
do I need different blocks between the axle and springs to put it at the correct height?
front axle:
is it better to have a dana 60 without the vaccuum axle disconnects?
brake lines:
are the lines longer on a 4x4 than on a 4x2?
Anything else I need to consider?
rear axle:
front axle:
brake lines:
