Frantz filter
Retractable running boards
White Knuckle Offroad Rock Sliders for Longbed
Old thread I know, but I'm happy with the Frantz I've run for many years and miles. Scott used to be the tissue of choice and is still what I use. I've copy and pasted a post from '07 on my truck below about a along'ish term test with Delo 15w40 and a frantz. Also on loosing oil, if I let the truck set overnigh I loose basically no oil due to drainback and the canaster is dry. Also no leaks.
2007 post;
Truck has 220,000 miles. Run Delo 15w40 with Frantz by-pass (2k element changes on the Frantz) and Stratapore main filter.
Last year I started a long term test with 5k sampling. Each time oil came back good to continue running, no unusual numbers on anything. I finally changed oil and the Fleetguard filter at the 1 year mark with 23,000 miles on both the oil and Stratapore filter and sent in a sample, again everything good to continue running.
I did add about 4 qts of make-up oil over the year which supplemented the additive package and the Frantz kept things clean.
While according to the analysis I could have continued without a change, I just felt better changing the oil at the one year, 23k mark. I'll now likely stick with a annual change with one 10k analysis, then change at 20k.
I did do one analysis on the wifes 98 on a 10k change and it had no special filters, just a Stratapore and it too came back good to continue running. I'm convinced that many change oil (and filters) far more often than necessary, but their money and truck.
moparguy, Nov 8, 2007 Report
