Originally posted by Gary - KJ6Q
Ralph, I suspect you will find the same issues as I did where the 24 valve engines are concerned - it can be VERY difficult to get the high degree of filtering we're looking for, and at the same time get adequate flow of fuel to the VP-44 on anything close to a stock fuel delivery setup - the 2 goals are diametrically opposed to each other!
This is not an issue with bypass oil filtration, since a high rate of flow is not an issue, high filtration is! But things are different where a full-flow *fuel* system seeking extremely high filtration rates is concerned.
The VP-44 absolutely MUST HAVE adequate flow rates to not only feed the engine, but also to cool and lube the pump - to do that requires the ability to flow approximately 45 GPH at even the HIGHEST loads placed upon the engine - and at inlet PSI to the VP-44 at something close to 10 lbs. or so (my guesstimate... ).
Try to do it with LESS, and you will leave yourself open to pump failures, unhappy customers - and possible expensive liability issues...
I can't speak as to other injector pumps and fuel delivery setups - but that's the way I see it with trucks like mine. Mine will work fine because I have added a pusher pump to my fuel delivery system that provides the needed additional fuel pressure and flow needed to overcome the restriction of the Frantz - and is what *I* consider the absolute MINIMUM needed for use with filters like these.
"The weakness of bathroom tissue filters is leakage around the core. "
Frantz seems to have effectively addressed that issue on their filters by going to a larger diameter center post that provides a tight fit to the TP core, which then is increased as internal pressure in operation eliminates any remaining leakage path. On my older oil unit, it was easy enough to simply place a couple of neoprene O-rings around the center post to provide a snug fit - operational pressure then completed the seal to the point you could easily see the indentations inside the core on used filters where firm contact had been established.
Good luck with your setup.
Thanks for the encouragement. I only have two Frantz's left. They are the old ones for 1 1/2" tp or the Frantz element. I haven't sold the Frantz since Diffusion Technologies owned them. I have a Frantz on my air cooled diesel at work. I was thinking about sleeving it with copper. I sleeved my old M-100 Motor Guard. I have the Frantz hanging upside down on the fuel. The other Frantz is on a Ford C-6 transmission. I returned my over 40 year old Frantz. It has the knobs. It has sentimental value to me. You can imagine how much money it saved me in over 30 years of use.
I was installing a Gulf coast filter on a John Deere tractor. The guy said my uncle had tp filters on his farm equipment but they didn't look like that. I lifted the hood on the old Impala and showed him the Frantzes. He said thats them.
There is definately some interest in submicronic filters. After 40 years I will stay with TP. It has served me well. I know that with a good fuel pump the TP filters can clean 1 GPM.
Ralph
