This is following freakn brakes here
https://www.turbodieselregister.com/forums/showthread.php?threadid=74486
I am going through these damn brakes again!!!!!!
about 9 months, 5,000 miles, three rear brake adjustments, and again I have not a good pedal.
NO lights of any sort, i stop reasonably well, but pedal travels all the way to within 2" or so of floor, if i push harder the pedal will go all the way to the floor. everytime before if i felt pedal travel was too much i adjusted the rear brakes, but this last time it did not have any effect of the pedal travel. pedal has just a hint of possibly not being there when you need it most.
I decided i was sick of trying to decide if it was the abs do hickie, so i made a stopper to go in with the spring to not allow that side to move at all. NO help.
pinched off lines, pedal still fell, ok master.
New master bled out perfect, bleed lines no air, brakes are worse then ever! ABS thing is still plugged and i still have not a good pedal.
Suggestions? any dodge recall, update or upgrade on these brakes.
What about if the prop valve/combination valve? dont know if they can become a problem?
no leaks, no balloning lines, all looks good.
anyone change masters to a bigger bore unit, or different setup, etc... . just seeing this master is 1 1/8 where chevy on basically same axles is 1 5/16 1 tons, or 3/4 ton is 1 1/4 on different axles.
done more brakes on this truck in the yr and half i owned it, then i have done on over 20 yrs on 5 other vehicles combined. First dodge i have owned, these brakes are giving it a bad name.
