Good point, some have used Mobil 1 with no modifier, try it first and see if you need it.
RE:
Just curious, why would you take out a 500,000 mile gear oil at 40,000, and replace it with a 50,000 mile gear oil?
(what data do you use to support that claim????)
Read the post by gmorrison: (bottom)
https://www.turbodieselregister.com...threadid=38708&highlight=eaton+warranty+mobil
"If you bought a new Pete or KW the warranty on the rear ends would be 100,000 miles. If you have a receipt showing you put in Mobil synthetic 75W-90 the warranty is automatically extended to 770,000 miles with both Eaton and Rockwell. If both Eaton and Rockwell put that much faith into the performance difference that synthetic gear oil makes in hypoid gear life, it would seem to follow that it becomes a no-brainer for our comparatively lightly loaded rears. .
Also, Eaton/Rockwell recommend a 200,000 drain interval with Mobil 1. LE mineral gear oil is not on Eaton/Rockwell's listing, BTW.
The synthetic 75W-90 will provide a cooler running rear end, improved fuel mileage or power and a longer lasting rear end. Also, the Mobil 1 75W90 has the limited slip additive included in the formulation.
George Morrison, STLE CLS"
Not bad for a "50,000 mile" oil, any oil manufacturer can make unsupported claims but this a real evidence in favor of Mobil 1, I wonder if Amsoil is listed by Eaton/Rockwell is an approved lube.
The LSD plates wear and leave the clutch fibers suspended in the oil etc. The manual says even with Synthetic oil to follow schedule B if used in severe service.
