friggin keyless entry is killin me
De-Badging
fuel milage
hey guys. .
the keyless entry on my '05 3500 is killin me. . I did a few searches and couldnt find what I was lookin for.
What I`d like to do, is instead of having to hit it twice to unlock all doors, I want to have it unlock all doors on the first button hit. That would be great. .
Have also tried the seat belt ding fix... could -not- make it work. Any other suggestions on it?
Thanks!
Jerry
RTFM! #@$%! It's in there! I just did this to my '05. . one click unlock. :)
For the seatbelt, just follow the directions except instead of "at least" it should say "exactly" three times you have to re-buckle the seat belt.
The instructions for changing the key to one time opens all the doors is in the manual. That is what RTFM means. ;)
I couldn't get the seatbelt ding thing to shut up either. As thejeepdude points out, it does say "at least three times". I always gave it one or two extra for good measure so that might be the ticket. Will try with exactly three.
it took a couple tries for me to get rid of the seatbelt ding, but it eventually worked. just follow the owners manual for the one click unlock of the doors.
How do you disable the friggin' PANIC alarm. I'm about ready to unplug my horns... damn thing goes off if I look at the remote wrong.
i've never managed to set mine off yet... i even think i have tried setting it off pressing the button and nothing???
Managed to set mine off the first time I had the truck out. Haven't done it since.
Try plugging the center seatbelt into the drivers recepticle and visa-versa
the panic function will scare the stuff out of you if you have air horns tied into the factory horns like I do. but I dare someone to break into my truck because it will wake the neighborhood!
I could not get the dag gum seatbelt chime to turn off either! I just use the middle seats lap belt and put it in the drivers seatbelt hole. Problem solved!
Is there a way to get ALL of the doors to UNLOCK when I get out? I normally get out, walk around the truck only to find all the other doors locked and I have to go back around to the drivers door to unlock the rest. I would like the auto lock on but would also like an auto UNlock. Can it be done?
YES! I found it in the manual and was successful. Now for the seatbelt chime, where in the manual are the instructions to disable that bugger? The auto door unlock instructions were on pg 21 of my 2005 owners manual.
I do that all the time.
I ran through the procedure to enable the auto unlock about 1 dozen
times. It dings and everything. But the doors never unlock. They do lock.
Like RMachda said, the manual says the truck has to be in Park for this
to work. It seems like they forgot to do something about that for 6-spds.
On the other hand, I brought this up in another thread a while ago and
somebody with a 6-spd said it worked for them.
I tried with the truck in 1st, Reverse, brake on, brake off, etc trying to
fool it into thinking it was in "Park". But it was not fooled. :)
I'm going to try the instructions again. Also for the seatbelt dinger.
To add a little humor to this, but it really works, put the manual in your bathroom. Your wife will be amazed to see you reading something on the hopper for the articles!! :-laf
Don't have the 6spd - but mabe clutch engaged (in)?
Have found that when you first use the manual you
skip to what you want.
Next you have to sit down and read "cover-to-cover"
and find all the stuff you missed before.
