This probly isn't the bes way to do a brake job,, but at 83K miles, it has worked purty good.
All I do is Open the hood, and take off the cover off of the brake fluid resevoir, brreak loose the wheel lug nuts, Jack up the front end, pull off the wheels, then pull off the calipers, pull out the old pads,, then with a C-Clamp, or some C shaped Vice-grips I push the caliper back, then I put the new pads on the calipers (I do this on both sides),, I then put the calipers back on, then the wheels,, I jack the truck down, tighten the lugnuts up, put the lid back on the brake fluid resevoir, and drive as normal, except for about 250-350 miles I use the brakes just a tad lighter (softer) than normal to allow them to seat.
I have done this exact routine about 4 times, only problem is I don't keep up with my rear brakes and the front rotors are starting to crack (like a stepped on Frito chip), but not only cause I didn't keep up with the rear brakes,, but because before I got this truck, it pulled a HEAVY (20K+)trailer without trailer brakes, and the previous owner didn't keep up with the rear brakes either.
MerrickNJr
P. S. I'm looking for some slotted, and/or cross drilled rotors for my '98. 5 3500.
Suggestons ?
