I have a stock 2005 2500 4wd Cummins.
The inside front brake pads are wearing at a much faster rate than the outside pads. Inside pads almost gone. Outside pads look new. The truck has 28,000 miles. Is this normal? If not is there a solution to this problem? The Chilton manual recommends that the rear pads be replaced when front pads are replaced regardless of condition. Is this true?
Thanks, Jakester
Thanks, Jakester
