front brake rotor p#s help
htt transmission?
Pn#s for front brakes
I need your help with part numbers for replacement parts for a 89 250 2wd . The caliper stuck and ate a nasty groove into the rotor. I need p#s and where to find the parts. As usual the gasser heads can,t get the right parts for me. I,m in huntsville Alabam. thanks for your help, Ken.
I have had good service from my NAPA guy. I got the numbers from him for the rotor (86025) and caliper 2423020 and 2423021 (left and right). That is the premimum rotor. There is a cheaper part but I use the better one. The calipers are remans. I am running brake parts from NAPA and have gotten good result.
The parts book shows two applications but the other item is hub and rotor (part number 85814 ) and is listed for a 3300 pound capacity front axle. On the 90 that I have, the hub and rotor are definitely two seperate parts.
Hope this helps.
James
Thanks for the info, i was on the phone with NAPA last night and it looks as if I might have to pull the rotor and take it in for a visual fit. Looks like some one had a similar part location problem before I bought the truck and replaced the original rotor with another type. All the replacement rotors that have been sent so far have had a hole too small to fit over the axel stub and wheel bearing assembly. The kicker is I am away from my tools and shop equipment and have to take it to a shop for any repairs. This is just a test I think. With your help though I,ll get it done. thanks again to all. K. E. .
