Cummins724
Bobalos said:I have an air ratchet, but it would surely not have the guts to get those bolts loose, which is why Im trying the leaverage approach.
the belt is on, but its still spinning the motor over. I tried rapping it with a hammer, but no joy there either.
what does the end of the "barring tool" look like. is it a 1/2" wratchet drive or something you can make in the garage or some special tool that really only works if right???
thanks guys
Bob
Just get a friend to hold the belt tight where the engine can't turn or hold the balancer from spinning. Maybe use a c-clamp on the belt to hold tension . I don't think you should put that much pressure on the nut for the vp44 gear or you could just hold that with a breaker bar.
