Wife caught that mine was making noise ( i couldnt hear it) so I pulled the shaft and time for a rebuild. Anyone have any pics or a procedure that works best for doing them? I have rebuilt old Ford Bronco driveshafts, but this appears to be a little differetnt. Also, can I get greaseable joints. PO said he repaced the joints with greaseable ones, but I see no zerks like my old broncos have. It does have external clips on the joint. Not sure if theis os factory or not. The front joint has internal clips with the plastic in the yoke. Is there a special tool to get the front bolts loose? I used a small Torx head allen wrench looking set to get broke loose. It almost seems like a "wobble" end torx would be great for it.
Thanks in advance for the help
