KParsons said:you guys are right. you must have big weight in the bed to pull stuck things. i pulled a small bulldozer with a 94 ford gaser in low range in 4wheel drive, i also had 5000lbs of stone in back. and a locker rear! kp![]()
No, you just need to get some slack, make sure everybody is ready, pin the throttle, hit the end of the strap, and stay in the throttle to dig four holes, that way the strap can't pull you back. You know a truck is really stuck, when you hook two or three high powered, mud tire equipped, locked in both ends offroad trucks, to free one stuck truck. The music of multiple trucks pulling in unison in the timber is beautiful!
FWIW, I rarely use low side when pulling stuff in the snow or ice. My CTD breaks the tires loose quick enough the way it is when traction is low, putting it in low side of the T/case and low gear just multiplies the problem.
Michael
