CMB
Hi All,
A couple of things, the front drive shaft grease fitting. WOW- Can some one post a picture of the type of needle used to grease the front drive shaft? At this point I bent a 4" needle (not the sharp type) slightly but still don't think I'm reaching the fitting properly. Even with the one handed type grease gun this seams to be a 2 person job. The sticker under the hood says lube with every oil change. Is this that critical? Will I see grease escape from somewhere when it's applied properly?
Second, while turning the front drive side wheel trying to locate the grease fitting it seams like I have a lot of free play in the front diff. In other words I can turn the tire almost 15-20 degrees before the drive shaft moves. Is that normal? I plan to pull the front diff cover off to check the wear pattern. What is the proper lash on the front end?
It's starting to get chili, time for fire wood. I'd like to address this before it gets to much colder. Thanks
