Well, not really grenaded, but the CV joint is destroyed. The ball in the center broke. A local driveling shop told me to just get a new one, it's cheaper. Only place I could find one is the dealer. They're getting the back shaft w/ knuckel assembly, should be in Fri. AM.
Anyone else ever had this happen? I don't use 4wd too much and NEVER when going down the road. The most abuse mine gets is when I go into 4-low if I need to slow down backing my trailer. The u-joints around the ball went out about 43K back, but this time they appear to be OK. Or at least as OK as they can be given the circumstances.
Why would this be a problem? Any ideas as to what can cause this to be a repeat problem? I don't care to have to replace it again.
I felt a vibe Mon night. It got progressively worse and eventually I had to pull off the freeway. As I was slowing to a stop, I thought something was about to explode. I had to look at the tach to see if the engine was running 'cause the shaft was making so much noise. Grabbed a maglite and looked underneath. No puddles and the transmission and diffs were relatively cool to the touch. I ended up driving at about 8mph for 3-4 miles until I could get into a big parking lot. Crawled underneath again and wiggled the shaft and just laughed. Not much guess work as it moved probably 1/2" side to side.
Dad was on his way with a backup '03 CTD (his). In the meantime I decided to start taking the shaft out. I had all the tools except the Torx, which dad had in his truck. Long story longer, I managed to get 6 of the 8 bolts out, 2 on the front weren't going to budge. Dad pulled my trailer home and we came back with a flatbed to haul my baby home. Dropped it off in the mechanics lot at 1:30am Tues. Later (obviously) it took the mechanic all of 10 minutes to pop the bolts.
I'm trying to remember for sure, but I think that's the first time in 287K of driving a CTD that I've been stranded. I guess I can't complain too much.
If the pics turn out I'll post them.
